Le message « Check security warnings of your Server » s’affiche sur fond noir lorsque je suis en modification d’un tableur collabora.
Ce message masque parfois les onglets. :-/
Impossible de fermer le message même en cliquant sur OPEN.
pyg
Juin 13, 2024, 11:50
2
Il s’agit d’un problème lié à Collabora :
La bonne nouvelle, c’est que ça devrait être résolu dans la prochaine version :
opened 10:04AM - 12 Jun 24 UTC
closed 01:31PM - 12 Jun 24 UTC
**Describe the bug**
After upgrade to Collabora CODE 24.04.4.1.1, a popup appea… rs repeatedly while editing a document with the message "Check security warnings of your server" (screenshot 1). Opening the details, there are two possible outcomes: either there are no issues found but a notice "The is_admin user property is set" (screenshot 2) or an actual error "The is_admin user property is not set" (screenshot 3). See also [this post](https://help.nextcloud.com/t/security-warning-the-is-admin-user-property-is-set/194935) in the Nextcloud help forum.
**To Reproduce**
Steps to reproduce the behavior:
1. Check that Collabora CODE 24.0.4.4.1.1 is installed.
2. Open a text document using Collabora.
3. Start editing and wait for the popup to appear.
**Expected behavior**
No popups or at least no recurrence after checking their contents.
**Screenshots**
Screenshot 1:
Screenshot 2:
Screenshot 3:
**Client details:**
- OS: Debian bookworm
- Browser: Firefox
- Version: 115.11.0esr
- Device: Desktop
## Server details
**Operating system**:
Debian bookworm
**Web server:**
Apache/2.4.59 (Debian)
**Database:**
mariadb Ver 15.1 Distrib 10.11.6-MariaDB
**PHP version:**
PHP 8.2.18
**Nextcloud version:**
28.0.6
**Version of the richdocuments app**
8.3.7
**Version of Collabora Online**
collabora/code:24.04.4.1.1 Docker image
**Configuration of the richdocuments app**
"apps": {
"richdocuments": {
"disable_certificate_verification": "",
"enabled": "yes",
"installed_version": "8.3.7",
"public_wopi_url": "https:\/\/redacted.host.name",
"types": "prevent_group_restriction",
"wopi_allowlist": "172.0.0.0\/8",
"wopi_url": "https:\/\/redacted.host.name\/"
<details>
<summary>Logs</summary>
#### Nextcloud log (data/nextcloud.log)
(empty)
#### Browser log
Unknown server audit entry: certwarning bundle.js:24657:46
</details>
(mais quand ? )
tcit
Juin 14, 2024, 6:08
3
C’est patché côté Nextcloud, côté Collabora le patch devrait être sorti dans les prochains jours.
Hello.
Avez-vous des nouvelles de correction de ce bug ? J’ai aussi le problème, et ça devient fatiguant à la longue, d’autant que ça revient de plus en plus souvent je trouve.
tcit
Juillet 7, 2024, 6:46
5
Nous avons essayé de mettre à jour vers la version qui corrige ce bug, mais d’autres soucis non liés sont apparus, donc nous sommes revenus dessus pour le moment.
tcit
Août 28, 2024, 6:54
6
Ce souci est maintenant corrigé.
