Petite question pour savoir si c’est normal ou si c’est juste que j’utilise mal le truc…
J’ai créé les plages horaires comme expliqué dans le tuto calendy précédent. Cependant, bien avant l’arrivée du framaspace j’avais déjà un framagenda perso, que j’ai partagé sur mon compte framaspace ce qui permet depuis l’agenda du space de voir toutes les infos, mais je n’arrive pas à le sélectionner comme 2e agenda à vérifier pour déterminer mes disponibilités, ce qui est embêtant car si j’ai des rdv perso, ça coince du coup…
Une idée ?
Merci d’avance !
Aurélie
tcit
December 30, 2024, 7:50am
2
À priori la gestion des conflits n’est effectivement actuellement possible qu’avec les agendas souscris, uniquement les agendas locaux.
opened 05:06PM - 02 Dec 21 UTC
closed 06:18AM - 15 Nov 24 UTC
2. developing
enhancement
Feature: Appointments
Thanks for reporting issues back to Nextcloud! This is the issue tracker o… f Nextcloud, if you have any support question please check out https://nextcloud.com/support
This is the bug tracker for the web-calendar component. Find other components at https://github.com/nextcloud/
Everything that is related to the CalDAV server, meaning it does not only affect the web-calendar but also your mobile and desktop clients, belongs in the Server repository: https://github.com/nextcloud/server
For reporting potential security issues please see https://nextcloud.com/security/
To make it possible for us to help you please fill out below information carefully.
You can also use the Issue Template application to prefill most of the required information: https://apps.nextcloud.com/apps/issuetemplate
If you are a customer, please submit your issue directly in the Nextcloud Portal https://portal.nextcloud.com so it gets resolved more quickly by our dedicated engineers.
Note that Nextcloud is an open source project backed by Nextcloud GmbH. Most of our volunteers are home users and thus primarily care about issues that affect home users. Our paid engineers prioritize issues of our customers. If you are neither a home user nor a customer, consider paying somebody to fix your issue, do it yourself or become a customer.
**Is your feature request related to a problem? Please describe.**
As a user I might have calendars shared to me by other users, e.g. a company-wide calendar.
**Describe the solution you'd like**
It would be nice if I could select that shared calendar for appointment conflicts as well. Then company-wide events would also block appointment slots.
**Describe alternatives you've considered**
N/a
**Additional context**
- [x] https://github.com/nextcloud/server/issues/30068
